Old 14th Sep 2017, 2:57 pm   #1
Al (astral highway)
Al (astral highway)'s Avatar
Default What would happen if I made an MW pantry TX aerial like this ?
Basically , for use around 1.5MHz, an antenna made of say 4 metres of coax but with the Earth braid outer swapped ... outer braid to the load and the core as ground , then the termination connected with a 50R resistor.
Al
Old 14th Sep 2017, 3:42 pm   #2
Default Re: What would happen if I made an MW pantry TX aerial like this ?
It would radiate a weeny bit, most of the power would be dissipated in the 50 ohm resistor.
Old 14th Sep 2017, 8:59 pm   #3
Ed_Dinning
Hi Al, and you might get a lobe from your 50R depending on its type and if screened.
Ed
Ed_Dinning is offline
