18th Sep 2017, 8:32 am | #41 |
Re: Triang Children's Record Player
Alright, good to know. I may end up buying a small amount for this then.
18th Sep 2017, 8:56 am | #42 |
Ditto here. Metallic lead is quite stable and relatively benign. When it gets vapourised and inhaled, or dissolved and ingested, it can indeed be harmful, but the exposure in hobby-style soldering repair work is negligible. Of course it is always wise to avoid breathing in any fumes, which mostly emanate from the flux, so work in a well-ventilated area.
18th Sep 2017, 9:02 am | #43 |
So from what I'm understanding, I need Multicore metallic lead solder, correct? Just making sure I'm getting it right before making any purchases.
18th Sep 2017, 9:06 am | #44 |
60/40 tin lead multicore solder.
Lawrence. |
18th Sep 2017, 9:15 am | #45 |
18th Sep 2017, 9:20 am | #46 |
It says it's flux covered, I'm not familiar with that type, I've only ever used multicore flux type.
Lawrence. |
18th Sep 2017, 9:25 am | #47 |
By any chance could you link me some solder that you think would work?
18th Sep 2017, 9:35 am | #48 |
18th Sep 2017, 10:59 am | #49 |
Leaded solder is almost harmless unless it is mixed with acid even in small quantities.
Leaded water pipes caused health issues in locations where drinking water comes from areas with acid soil. If blueberries grow wild in the hills do not let lead get into contact with the local drinking water. Limescale makes lead pipes safe. For electronic equipment it is completely safe. |
18th Sep 2017, 12:28 pm | #50 |
Not quite what I meant.... photo of the underside of the arm at the stylus end with the ruler alongside the rusty mess so we can see how much space is available when said rusty mess is dug out.
18th Sep 2017, 12:34 pm | #51 |
For an initial supply of solder, PM me your address and I'll send you a free large letter's worth. (About 100g less whatever the packing weighs!)
Any of the various suggestions including your own will be fine too. If you do boot sales or autojumbles and the like, keep your eyes open for the occasional bargain. Even 50 year old stuff should be fine!
18th Sep 2017, 1:06 pm | #52 |
Ah okay, here attached one. And you don't have to send me any solder if you don't want, but if you're completely okay with it then I will.
18th Sep 2017, 2:37 pm | #53 |
Good photo. It looks like a cartridge about 2cm max would be needed. A Chinese cartridge I've got here is about 3cm including its tags. I wonder if anyone has sacrificially stripped one down to its tiniest form for possible use in a case like this.
A Sonotone 9TA might be small enough since being so slim it could go a little way up the arm past the "head-shell". I've got a couple of stereos that pre-date the current crop of Chinese carts so I'll measure those just in case. Graham
Half my stuff is junk - trouble is, I don't know which half! |
18th Sep 2017, 2:59 pm | #54 |
Okay cool, thanks. If you find one that would fit it for sure would you please link it here? Thanks a lot.
18th Sep 2017, 3:29 pm | #55 |
I've just measured the cart in a music centre in the loft and it is about the same as the current Chinese ones so no help there.
Then I measured one in an Alba SuperSound which features a BSR belt drive turntable - I don't know what model number. The cart in it is a bit shorter than the Chinese ones but it's a whole lot slimmer than even a 9TA. So those with more BSR knowledge than me might be able to pin it down from that. Graham
18th Sep 2017, 3:58 pm | #56 |
Probably a BSR SC11M or SC12M or H.
Edward. |
18th Sep 2017, 4:17 pm | #57 |
Okay, I'll note those two down, thanks.
18th Sep 2017, 5:31 pm | #58 | |
PM that address!
18th Sep 2017, 5:43 pm | #59 |
Alright, sent. Thanks very much
18th Sep 2017, 6:00 pm | #60 |
Okay, another question I have, how would I check if the motor is working? I've been told that I need to make sure that is working before spending any money.
