13th Sep 2017, 6:34 pm | #21 |
Re: French Miracle 510 1937 too many valves?
Pete
Thank you for the advice, I have a couple of 110v sets and have found a auto transformer,but they are there for another day! Lawrence I have tried to follow the capacitors back The 0.025MF cap that goes to pin 4 on valve 42(A) is connected to via a resistor to pin pin 2 on Valve 42 (B) The capacitor that goes to valve 42 (B) is connected to a tuning coil ( I think ) with 4 connections the other 3 of which are connected to the unmarked valve which you suggested is a 6A7 Does this help? I have attached my attempt at a partial circuit for these two 42's Any thoughts on the suitability of two 473 1KV in parallel as replacements for the 0.025MF caps? Many thanks Philip |
13th Sep 2017, 7:28 pm | #22 |
Is your reverse engineered drawing of the output stage starting to resemble the schematic in the link below (scroll/drag down to book page 585, the schematic is Fig. 13.44) Ebb on that schematic means HT:
http://www.paleoelectronics.com/RDH4/CHAPTR13.PDF Lawrence. |
13th Sep 2017, 7:53 pm | #23 |
Oh!
Yes I think it probably does I will need an hour in a quiet room with a cup of tea to verify I will come back to you tomorrow Thanks Philip |
13th Sep 2017, 10:28 pm | #24 |
473? I assume you mean, is 0.047uf
Two in SERIES = nearly 0.025uf, not parallel. Half the value, twice the voltage. |
14th Sep 2017, 12:56 pm | #25 |
Lawrence
Yes, as far as I can work out, except R5 and R6 don't appear to exist .. see pic Boater Sam...told you I was a novice! Blue ceramic discs marked as 473 1kv so 47nF 47000pF 0.047uF there two in series equals 0.0235uF ...suitable to replace my "that caps" marked 0.025MF Opinion..if I replace the 8,16,and 10uF electrolytics (8 and 10 with 10's and 16 with a 15) and the two 0.025uFs is it worth some power on...bearing in mind usual cautions and caveats Will be via lamp limiter etc. Philip |
14th Sep 2017, 1:14 pm | #26 |
The non existence of R5 and R6 is of no real consequence, the phase inversion appears to be done by one of the output valves as was suspected earlier, but there's a fly in the ointment, there appears to be a resistor that you've drawn in that connects to C2, is it definitely connected to C2? If so where does the other end connect to?
Yes I would replace the electrolytics and the grid coupling capacitors before firing up. Lawrence. |
14th Sep 2017, 1:15 pm | #27 |
0.025 is very small for an audio coupling cap, I'd just put one 47n @ 1000v in if you already have it. 400v would do.
Your electrolytic values are fine, does it really need them? They may well reform OK. Check transformers for continuity, especially the output before getting too involved.. Yes, get it on a lamp as soon as possible, get it working , then find out what it really needs. Then change one thing at a time so you don't have an introduced error you can't find. Sam. |
14th Sep 2017, 1:20 pm | #28 |
0.025uF isn't a very small value for a coupling capacitor, I've seen 0.001uF and sometimes lower....
Lawrence. |
14th Sep 2017, 1:33 pm | #29 |
I knew someone would jump on that remark! Just trying to save a few pence that don't need to be spent.
I've seen smaller and larger, not bragging, hey ho. Last edited by Boater Sam; 14th Sep 2017 at 1:34 pm. Reason: added |
14th Sep 2017, 2:53 pm | #30 |
Lawrence
The said resistor (orange body, black end I think yellow dod, it pinged off) measures 330kohm Is connected via the yellowish wire to pin 4 and one end of the 0.025uF cap, the other end of the resistor goes to the chassis. Is this a problem? All seems very untouched ? ( except for choke and replacement 16 uF cap) Boater Sam I've already got the electrolytics, and the rubber insulation on the 8 and 16 have perished, so I will replace, makes me feel like I've done something Philip |
14th Sep 2017, 3:06 pm | #31 | |
The resistor I was referring to is the hand drawn one that's running north south in the top left hand side of the annotated schematic in post#25. Lawrence. |
14th Sep 2017, 5:05 pm | #32 |
Whoops, I have gone back to the chassis rather than my wiring sketches, and I now don't know where I thought that hand drawn was, sorry
Philip |
14th Sep 2017, 8:32 pm | #33 |
Update
Electrolytics replaced, "coupling' capacitors replaced ,mains lead replaced, power applied via lamp limiter...... Result..crackly wave change switch,scratchy volume control and a significant amount of hum,but reception on all the wave bands, a very pleasing result But more questions, Can I use the earth from the domestic mains supply as the ground for the aerial? The house has an earth rod type earth? I have read elsewhere that one end of a long wire antenna should be grounded..to reduce the risk from lightning is this correct? My plan is now to clean wafer switch,valve pins and volume control with switch cleaner and search for the reason for the hum...any suggestions Many thanks in advance Philip |
14th Sep 2017, 10:29 pm | #34 |
Mains earth is sometimes disappointing when used for a radio, as it can be electrically noisy. You may get better results with a separate earth stake. But, there is no harm in trying ..... But consider yourself lucky, if it's any good. Do not make any connection to the live or neutral pins of the plug.
15th Sep 2017, 8:24 am | #35 |
Long wire aerials used to have a shorting link to ground for use in thunder storms. It is doubtful if it would have made any odds in the event of a strike and of course the aerial would not work shorted to ground.
15th Sep 2017, 10:28 am | #36 |
The difference a night makes!
Returned to set this morning, no radio signals at all! Any band Set works on gram / pick up with iPod, but the volume control has very little effect, more like a tone control Suggestions? |
15th Sep 2017, 11:08 am | #37 |
Is the set now on full mains, without the lamp?
15th Sep 2017, 12:05 pm | #38 |
Yes, on full mains
But there are developments I ran with iPod for about an hour till the battery ran out and turned in to long wave..and there is radio 4 ( and others) Thoughts? Dry joint?, bad contact? Philip |
15th Sep 2017, 12:15 pm | #39 |
Dirty wave change switch?
Without checking voltages when not working it's hard to guess. Intermittent faults are the devil to fix. |
15th Sep 2017, 4:15 pm | #40 | |
Even in clear weather you can get quite a belt sometimes from contacting an ungrounded aerial.
