Old 8th Sep 2017, 9:52 pm   #1
martiR2R
Default Unilab variable power supply
These are 28 years old, not sure if that counts as vintage!
Recently aquired 3 of these (ex schools chemistry lab) but have found next to nothing on the web. They seem very basic, big lump of a transformer, a mini "variac" and half a dozen components.
Could the "variac" be used on its own, within it's limit 0-220V @ 1.4A ?
Any info or suggestions gratefully received.
Thanks
Martin
ID:	149131   Click image for larger version
ID:	149132   Click image for larger version
ID:	149133   Click image for larger version
BVWS Member (lapsed!)
martiR2R is offline
Old 9th Sep 2017, 9:02 am   #2
Radio Wrangler
Radio Wrangler's Avatar
Default Re: Unilab variable power supply
It's a mains voltage variac, and it was used to adjust the mains voltage into the big fixed ratio transformer, so it could be used on its own. The output won't be isolated from the incoming mains, of course, it's a variable autotransformer.
Radio Wrangler is offline
Old 9th Sep 2017, 10:40 am   #3
turretslug
turretslug's Avatar
Sounds like an eminently useful find and with one-into-two potential- the variac with a good rating to cover most vintage radios (if not thirstier things like TVs) already in a safe metal enclosure, and a transformer with the capability to become the heart of a 0-20V 5A bench supply. Nice one.
turretslug is offline
Old 10th Sep 2017, 6:38 pm   #4
martiR2R
Thanks chaps, much obliged.
Martin
martiR2R is offline
