Old 9th Sep 2017, 6:48 pm   #1
Freya
Freya's Avatar
Default National Panasonic TR-565G Component television
Friend bought this around for me to look at for him, it has reduced width leaving about 10mm either side. Other than that it works fine.
I have not been able to find a manual for it online, are there any stock faults for these before I strip it down which looks to be quite involved.
Thanks
ID:	149189   Click image for larger version
ID:	149190   Click image for larger version
ID:	149193   Click image for larger version
Stephen
Freya is online now
Old 9th Sep 2017, 7:18 pm   #2
John123
Default Re: National Panasonic TR-565G Component television
Leave it running for a while. If the width increases, most likely a slow electrolytic in the horizontal. You could simply replace all within the vicinity if unsure.
Regards,
John
John123 is offline
Old 9th Sep 2017, 7:22 pm   #3
Freya
Freya's Avatar
It was on for 4 hours today with no change, the capacitors would normaly be my first call though.
Stephen
Freya is online now
Old 11th Sep 2017, 2:29 pm   #4
kevinaston1
Found this on the Radiomuseum website, any help to you?
Kevin
kevinaston1 is offline
Old 11th Sep 2017, 2:36 pm   #5
Freya
Freya's Avatar
So far changed all electrolytic power supply capacitors along with the ones in the horizontal section C417 C418
No change so far but still investigating.
Stephen
Freya is online now
Old 11th Sep 2017, 3:19 pm   #6
Welsh Anorak
Welsh Anorak's Avatar
Hi
Can't see in the pictures, but many small-screen sets used a high value capacitor to couple the line scan coils. That could be a suspect if there is one.
Glyn
PS Should engage brain first - looking at the excellent diagram I'd look at C412 and C410.
Welsh Anorak is offline
Old 11th Sep 2017, 3:30 pm   #7
Freya
Freya's Avatar
Thanks Glyn,
I have C412 out at the moment so we are one the same track at least. Now to test it.
Stephen
Freya is online now
Old 11th Sep 2017, 4:38 pm   #8
Freya
Freya's Avatar
Those capacitors check out fine, so went back to the power supply again.
Found D75 which I believe to be a 5.1volt zenner diode with no voltage across it, testing shows an almost identical short both ways.
Stephen
Freya is online now
Old 13th Sep 2017, 10:16 pm   #9
Freya
Freya's Avatar
The 5.1volt Zener diode D75 restored normal operation.
Think this can be closed now
Stephen
Freya is online now
