31st Aug 2017, 8:03 pm | #1 |
Vintage Bush TP50 Reel to Reel
I just bought a vintage Bush TP50 Reel to Reel recorder as a surprise for my husband - but it did not come with an instruction manual. Does anyone know where I can get one? I would appreciate any and all information! Thanks.
31st Aug 2017, 8:51 pm | #2 |
Re: Vintage Bush TP50 Reel to Reel
This is it: http://www.radiomuseum.org/r/bush_tp50.html
It uses the very common BSR TD2 deck, which was a reliable design. However, if this recorder is unrestored then it is likely to need electrical and mechanical work before it can be used safely and reliably. |
31st Aug 2017, 9:47 pm | #3 |
The earliest production used TCC wax dipped paper capacitors. Later production used Hunts Moldseals. Either way, they will need replacing. These are nice machines, with decent electronics.
1st Sep 2017, 10:50 am | #4 |
the BSR TD2 tape deck is a modified version which has a pause position on the joystick control
1st Sep 2017, 12:45 pm | #5 |
Thank you all for the information. But I have no idea who I could take this to for restoration. Any ideas in Lancashire?
1st Sep 2017, 12:53 pm | #6 |
I have a copy of the instruction manual for this model.
Let me know if you still need it, and I will scan it for you. Roy |
1st Sep 2017, 2:45 pm | #7 | |
To request help, post here: https://www.vintage-radio.net/forum/...play.php?f=145 |
1st Sep 2017, 7:46 pm | #8 |
Thank you, Roy, I would love a scan. What do I have to do? I bought a download of the manufacturer's service data, but it wasn't what I had in mind! I just want to know how to use the machine. Please let me know.
2nd Sep 2017, 9:26 am | #9 |
I will scan the instruction booklet for you today and post it here as a PDF. It is a 12-page booklet with full guidance on how to use the machine.
Roy |
2nd Sep 2017, 12:35 pm | #10 |
Instruction manual attached as promised.
Roy |
3rd Sep 2017, 6:10 pm | #11 |
You are a hero, Roy! Thank you so much for taking the trouble - I really appreciate it. Cheers, friend.
5th Sep 2017, 10:23 am | #12 |
I go all over the Country servicing vintage electronics, I will send you a PM.
