Old 27th Aug 2017, 9:38 pm   #1
Paulus.d
Default Korg M1 synth
I recently acquired one of these.... it has cosmetic and hardware problems that occur with age ...as a refurb project i'm quite pleased with it.
It had a new battery replaced but they couldn't replace the factory sounds so ditched it ....I did that and got it playing except for only one out socket - other was dead..
I stripped it ready for work and just simply read the volts coming out the PSU ..these read 6.83v instead of 5 and just over 16v iinstead of 12.....these are off load ....... are these correct or is recapping gonna be necessary
Paul
Paulus.d is offline
Old 27th Aug 2017, 10:39 pm   #2
nigelr2000
nigelr2000's Avatar
Default Re: Korg M1 synth
That's pretty close off load try reading in on load as it will be more accurate. VR1 in the PSU sets the 5 volt line so if that's right the 12 volt lines will be too. Set it with a load on though.
nigelr2000 is offline
Old 28th Aug 2017, 5:36 pm   #3
Paulus.d
Measured on load the PSU read almost exactly dead accurate!, so today connected all the PCB's up while it was on my desk....the resolder of dry joints had made no difference, however there is a burned out resistor and a rather bad looking cap on the DAC board ...
Paul
Paulus.d is offline
Old 29th Aug 2017, 7:29 pm   #4
dglcomp
if you didn't have it already here is a link to the service manual if it helps,
http://www.manuals.fdiskc.com/flat/K...e%20Manual.pdf
dglcomp is offline
