3rd Sep 2017, 2:23 am | #41 |
Re: Can anyone identify these valves?
Some electrical measurements are unavoidable to discriminate between the 12.6v and 6.3v heated versions of almost all the candidates.
Aspect ratio wise it looks taller than the common 6SJ7, 6SG7 so I wondered about 6V6 and 6L6, but I'm not sure about missing pins and whether all makers missed them. David
3rd Sep 2017, 8:28 am | #42 |
Number 8, 6N7 or 6AG7?
Lawrence. |
3rd Sep 2017, 8:57 am | #43 |
6L6, like 5T4, is h-u-g-e, so quickly ruled out, 5Z4 (another prolific quiet-place breeder....) too few pins, though envelope size about right. I'd forgotten about 6AG7! 12A6 I think also a size possibility, but likely a missing pin- the makers weren't going to miss the opportunity of saving a fraction of a cent per base if they could with IO's rolled and crimped pins it seems.
11th Sep 2017, 10:05 pm | #44 |
Number 7 tests OK as an EBL21.
I'm wondering about measuring inter-electrode capacitance to identify the pinout of number 8?
12th Sep 2017, 1:12 am | #45 |
What is the text on the bottom of number 8?
12th Sep 2017, 8:07 am | #46 |
It says "LICENSED ONLY TO EXTENT INDICATED ON CARTON".
12th Sep 2017, 10:03 am | #47 |
12th Sep 2017, 8:19 pm | #48 |
Heater resistance cold is 1.5R.
The highest capacitance to the heater pins, by far, is to pin 1, so I'll assume that's the cathode.
12th Sep 2017, 8:33 pm | #49 |
Pin 1 is usually the metal.
Lawrence. |
12th Sep 2017, 9:08 pm | #50 |
Indeed it is .
With three pins identified there's only five to go.
12th Sep 2017, 9:12 pm | #51 |
I like it.
Lawrence. |
