Old 20th Aug 2017, 5:07 pm   #1
saddlestone-man
Default Identify this Radio?
Hello All
I picked up this interesting (to me anyway) radio at the Rugby rally today. It looks like something from the US that's found its way over here. There's a three gang tuning capacitor so it has an RF amplifier. It looks military, but not rugged enough to used anywhere near combat.
The valves are: 7A7, 7Q7, 7A7, 7B6, 7C5.
It's rigged to work off external power, but it looks like it could have originally been fitted with a mains transformer and rectifier.
It has SC 6732A printed on the rear panel. Can anyone put a date and make/model number to it.
best regards ... Stef
ID:	148159   Click image for larger version
saddlestone-man is offline
Old 20th Aug 2017, 5:30 pm   #2
Cobaltblue
Cobaltblue's Avatar
Default Re: Identify this Radio?
I can't help you with this particular set but it looks like what is often referred to as a NAAFI Set.
Mike T
Mike T BVWS member.
www.cossor.co.uk
Cobaltblue is offline
Old 20th Aug 2017, 5:32 pm   #3
G6Tanuki
G6Tanuki's Avatar
Looks intriguing: the use of "Loktal" valves [rather than mid-WWII-era B7G types] would put it early in WWII timescales.
Definitely not a 'portable' - by the early-1940s Hallicrafters etc. had the likes of the "SKy Traveler" S29 on the market to address the niche: http://www.radiomuseum.org/r/hallicr..._s_29_s29.html
Lack of a BFO, however, marks it out as an 'entertainment' radio rather than a communications-set.
What are its power-supply needs? The big transformer-shaped hole in the chassis and empty valve-socket make me think it was originally intended to run on AC supplies.
G6Tanuki is offline
Old 20th Aug 2017, 7:47 pm   #4
turretslug
turretslug's Avatar
It's a near-certainty that "SC" is a Signal Corps (i.e. US) designation- a query on one of the American vintage websites might be fruitful, I wouldn't be surprised of lots of these were made for field "morale" purposes and then dumped NOS on the market post-war.
In a sympathy-for-the-underdog sort of way, I quite like the loktal valve series- like the rimlock series, the presentation may have been misconceived, but the valves per se do a perfecrly good job for the most part. The main short-coming is short pins, leading to contact dependability problems. Quite a bit of the more "peripheral" US military kit seemed to use them- could it be that the earlier but tough and proven metal octal types were favoured for front-line kit and loktals, appearing in quantity for civilian use just pre-war, were used for less critical kit to ease possible production bottle-necks?
Maybe the original mains transformer was a 110V-only type, or just a commercial quality item that expired at some point.? I'd say this set ought to be a good performer, but the elephant in the room is the declining AM transmitter scene! Shame about the lack of LW, but hardly surprising in a US-originated set.
The B9a valve-socket on the LHS suggests something like a 7Y4-to-EZ80 adaptation?
turretslug is offline
Old 20th Aug 2017, 8:32 pm   #5
G3VKM_Roger
G3VKM_Roger's Avatar
I did a search on US WW2 morale radios and a lot of images came up. This link shows something like yours:
http://www.ohio.edu/people/postr/bapix/6000-bac.htm
Google images was my search engine.
73
Roger
G3VKM_Roger is offline
Old 20th Aug 2017, 8:32 pm   #6
Alf
Alf's Avatar
Another clue as to its American origin is the use of BC for Broadcast instead of medium wave.
Alf is offline
Old 20th Aug 2017, 8:41 pm   #7
saddlestone-man
Thanks Roger, that looks very like my radio, but a different version. Well spotted!
My radio is powered by flying leads for the HT and LT, obviously after the original power supply was stripped out.
Old 20th Aug 2017, 9:03 pm   #8
ms660
ms660's Avatar
https://www.worthpoint.com/worthoped...iver-246029409
Lawrence.
ms660 is offline
Old 20th Aug 2017, 9:10 pm   #9
G3VKM_Roger
Ummm, no doubt these radios were occasionally carried or used in jeeps, but to describe it as a "Jeep Radio" is pushing it a little! Having said that, I do have a photo of a BC-610 transmitter in a jeep but I'd hardly describe the '610 as a jeep radio!
Roger
Old 20th Aug 2017, 9:19 pm   #10
Station X
Station X's Avatar
Looks like it may have originally been fitted with a vibrator and associated transformer.
Graham. Forum Moderator
Station X is offline
Old 20th Aug 2017, 9:32 pm   #11
saddlestone-man
I've just been looking at some pictures of radio installations in Jeeps and as expected, they are all of rugged transmitter/receiver/control unit combinations. Judging by the sort of bumps and shaking about that jeeps typically endured, I don't think my radio would have lasted very long.
Old 20th Aug 2017, 9:44 pm   #12
ms660
ms660's Avatar
It's hardly an "installation" type radio, neither is it a comms set, quite likely they were carried around in some Jeeps just as much as in any other vehicle for general entertainment.
Lawrence.
ms660 is offline
Old 26th Aug 2017, 10:45 pm   #13
majoconz
majoconz's Avatar
The transformer and other power supply components were perhaps stripped out as it may have been for 117v 60Hz - not that the frequency matters much.
Cheers - Martin ZL2MC
majoconz is offline
Old 26th Aug 2017, 11:50 pm   #14
Herald1360
Herald1360's Avatar
Originally Posted by majoconz View Post
......... it may have been for 117v 60Hz - not that the frequency matters much.
It can, if the 60Hz transformer design is cheesepared to the limit it will overheat on 117V 50Hz supplies.
....__________
....|____||__|__\_____
.=.| _---\__|__|_---_|.
.........O..Chris....O
Herald1360 is offline
Old 15th Sep 2017, 8:35 am   #15
jsbhavsar
Does the 3-section tuning gang indicate that the radio had a "tuned RF stage"?
jsbhavsar is offline
Old 15th Sep 2017, 3:16 pm   #16
AC/HL
AC/HL's Avatar
The circuit diagram linked to in post 8, although it's only a thumbnail, shows an RF stage.
AC/HL is offline
Old 15th Sep 2017, 4:53 pm   #17
turretslug
turretslug's Avatar
Whilst it's a straightforward-to-use broadcast receiver, it's intended role could have involved it being sat on the ground on a remote Pacific island with whatever handy bit of wire could be found as an aerial, and with a fair amount of military comms rattling around in the vicinity at various frequencies- so both the extra sensitivity and front-end selectivity resulting from an RF stage would have been considered worthwhile.
Old 23rd Oct 2017, 11:43 am   #18
boxdoctor
As I understand it, the term "Jeep" was originally a U.S. military slang abbreviation for General Purpose, and subsequently became mostly associated with the ubiquitous Pick-up truck usually referred to as a "Jeep", as it was a general purpose vehicle. So Jeep in the original context could well apply to your radio. Tony
boxdoctor is offline
