Old 24th Aug 2016, 10:52 am   #1
johnny
Default Woodsons SR-12 receiver
Has anyone got any paperwork for a woodsons SR-12 receiver with circuit diagram etc.
Thanks
johnny is offline
Old 24th Aug 2016, 10:53 am   #2
Jon_G4MDC
Jon_G4MDC's Avatar
Default Re: Woodsons receiver
I'm not sure what this is. Any more info?
First thought was a VHF RX called a Search12 which I recall from late 70s.
Anywhere close?
Jon_G4MDC is online now
Old 24th Aug 2016, 11:38 am   #3
johnny
Default Re: Woodsons SR-12 receiver
Opposite end of the band, this is a LF receiver 1.6 to 3.8Mhz and 150Khz to 500Khz. All valves. It comes in rack with tx and rx and was probably made for fishing trawlers etc.
johnny is offline
Old 24th Aug 2016, 2:05 pm   #4
Jon_G4MDC
Jon_G4MDC's Avatar
OK - not what I had in mind.
Good Luck.
Old 24th Aug 2016, 3:32 pm   #5
johnny
I may need it as there is nothing on the Net about it at all, so going to be a tough one. Been running the valves in for a couple of hours and working out the wiring from the valve bases.
johnny is offline
Old 24th Aug 2016, 4:24 pm   #6
G8BBZ
G8BBZ's Avatar
Woodson's of Aberdeen who made your receiver are still in business in marine electronics in a big way, though I think they no longer manufacture equipment.
It may be worth giving them a call to see if they can help.
It may be worth posting a few pics if you can as a photo often jogs the memory..
Good Luck
Peter G8BBZ
Peter G8BBZ
G8BBZ is offline
Old 25th Aug 2016, 9:14 am   #7
johnny
Thanks for that, I have just been on the phone to them, but it seems that they don't have any info on it, although they will ask their older workers if they remember anything and get back to me.
ID:	129151   Click image for larger version
johnny is offline
Old 28th Aug 2016, 7:08 am   #8
G4XWDJim
G4XWDJim's Avatar
Johnny,
Here's a picture of my complete set up which worked well into the vmars net many years ago when I was keen. It always reminded me of Wireless Set 18 layout. A very neat compact design capable of about 15 to 20 watts output in good carbon mike AM.
The receiver has a direction finding capability which I never used. It also has the letters PIM, the meaning of which I found out but have now completely forgotten. Anyone know?
I remember it has Denco coils soldered in.
Here also is the circuit diagram. If it's not clear enough send me your email add. by PM. I do have some more info.
Jim
ID:	129296   Click image for larger version
G4XWDJim is offline
Old 28th Aug 2016, 12:06 pm   #9
Keith
Keith's Avatar
Delightful little rig, Jim. Shame it's no longer used...
Keith Yates - G3XGW
VMARS & BVWS member http://www.tibblestone.com/oldradios/Old_Radios.htm
Keith is offline
Old 28th Aug 2016, 12:57 pm   #10
G4XWDJim
G4XWDJim's Avatar
I know Keith. I've just lost complete interest in amateur radio. I've had 25 years or so when I was quite active in building, restoring and operating but I've got other hobbies now.
I'm gradually getting rid of almost everything.
Who knows in perhaps 10 years if I'm spared I might become interested again.
Jim
G4XWDJim is offline
Old 28th Aug 2016, 4:06 pm   #11
David Simpson
Johnny & Jim,
Please reconsider any thoughts of leaving old marine band radio telephone sets in the loft, or, dread of dreads, dumping them. Woodsons(3 sons of the original Mr Wood) of Aberdeen do still exist and supply the fishing fleet & offshore installations with comms equipment. They haven't built their own Tx/Rx equipment since the 60's. By the time I started to work for them in the late 70's, part-time, they were main agents for Sailor Radio equipment. HF AM & SSB, and VHF's. Which is what I mainly worked on. By then most of those old R/T's were obsolete.
Last I heard, they had some of the old circuit diagrams on micro-fiche, at their Goval House HQ outside Aberdeen. Ask for Mike Newman - the Boss, or his no2 - Robin. Mind you, they might have retired by now.
I just have the circuit diagram for the 120N HF(two TT22's in P - P) Tx from that era.
Regards, David
David Simpson is offline
Old 28th Aug 2016, 4:35 pm   #12
G4XWDJim
G4XWDJim's Avatar
David,
No fear. I won't be dumping it after all the time I spent on it.
Thank you for the explanation of the Woodson name I didn't know that. Can you explain the meaning of PIM seen on the front of the receiver.
Jim
G4XWDJim is offline
Old 28th Aug 2016, 7:17 pm   #13
GW3OQK Andrew
GW3OQK Andrew's Avatar
I can't resist having a go.
I see the PIM switch switches it into a condition for DF. That's AGC off, manual gain and BFO on. The meter then indicates audio output level. Disconnect the main aerial. The loop would be turned for a sharp audible null, corresponding to minimum meter reading, and the DF bearing and ship's heading noted.
If required the 180 degree ambiguity is resolved by connecting the main aerial to the sense terminal on the front of the receiver then turning the loop +/- 90 degrees (Perpendicular) until the loop signal is in Phase with the main aerial giving max Indication on the Meter. (One side would be somewhat stronger than the other.) There would be a Pointer on the loop's rotator wheel which would show the correct direction. (Refer to manual!)
Next apply correction from the DF calibration curve, and add the ship's (corrected) heading from the compass to get true (or magnetic) bearing from the ship.
I suggest PIM means Pointer Indication Meter and wait for the correct explanation.
73, Andrew ex MN R/O and DF bearing taker.
GW3OQK Andrew is offline
Old 31st Aug 2016, 8:32 pm   #14
David Simpson
Cant say what PIM stands for ,Woodsons-wise. But I suspect that Andrew is spot-on.
Their later range of 66TS Sailor Rx's did have a loop/sense aerial facility. My recent Loop/DF-ing experience has just been with my BEME Loop Rx's, and Coastal Radio Curlew Rx which worked "Consol".
Incidentally, back in the 50's, Woodsons lost out to Coastal Radio Ltd for supplying the RNLI with HF AM R/T's (C/R Curlew & Nimbus).
Regards, David
Old 31st Aug 2016, 8:45 pm   #15
johnny
Thanks Jiim for the circuit. Unfortunately, I dont have the transmitter, but do have the caseing which looks as if it was mounted against a bulkhead or wall. I am now looking for a psu for it either homebrew or the original one. Yes, the pim is for df'ing. Nice little receiver.
johnny is offline
Old 30th Aug 2017, 2:46 pm   #16
johnny
I fired up the filaments today for several hours, then applied just 50v ht for a few hours to see if the electrolytic caps will hold and so far so good. No speaker noise as yet, although I can hear some crackles when connecting HT. Next step is to increase HT slowly.
Thanks
J
johnny is offline
Old 30th Aug 2017, 7:27 pm   #17
Jon_G4MDC
Jon_G4MDC's Avatar
Hoping you get life out of it on the eve of the first anniversary of the last post!
Go for it
Old 31st Aug 2017, 1:23 pm   #18
johnny
Default Woodson's sr-12 dead
With full HT applied, there is no hiss from the receiver speaker. The speaker does crackle when low ht was applied, so this is working. Cannot find my signal tracer right now....AARRRGH I was wondering if there is a mute connection when used with its transmitter. Does anyone know ?
J
johnny is offline
Old 31st Aug 2017, 2:14 pm   #19
Station X
Station X's Avatar
Have you tried the obvious things like checking voltages around the output valve and output transformer?
Do you get a buzz when you touch the centre tag of the volume control with an insulated screwdriver?
Graham. Forum Moderator
Station X is online now
Old 31st Aug 2017, 8:51 pm   #20
johnny
Will check that tomorrow. Valves all warming up ok. No smoke or bangs, so looking good. Will probe around tomorrow when my brain is in gear and fingers have returned to normal. Its a slow progress here, due to medical and other issues.
johnny is offline
