Old 21st Aug 2017, 12:31 am   #1
beery
beery's Avatar
Default Best Friend Bakelite Hairdryer rewiring
Hi all,
Just a quick note about my 'Best Friend' Bakelite hairdryer.
This hairdryer had been a bit of a gimmick as far as I was concerned as I did not have any real use for it. However it turns out to be great for drying my baby girl's hair as she is easilly spooked by the noise of modern hairdryers.
Years ago I had renovated the hairdryer by feeding a new mains flex through the best part of the old cotton outer braid of the original flex. However, the length of braid that was left once I had removed the worn bits was really too short to make a practical mains lead.
So in order to make it usable I had to fit a new lead. Fortunately old style braided cable can now be obtained quite easily. In order to fit a new lead I had to strip the hairdryer right down. It really is a tight squeeze to fit the motor, switches and wires in. It was a very nasty job and I hope I never have to do it again!
Anyway I now have a useful hairdryer. It is much lighter than other vintage hairdryers I have seen and only draws 650W. Check out the photos and note the lovely toggle switches.
Andy
ID:	148168   Click image for larger version
ID:	148169   Click image for larger version
beery is offline
Old 23rd Aug 2017, 2:16 pm   #2
AC/HL
AC/HL's Avatar
Default Re: Best Friend Bakelite Hairdryer rewiring
Two posts moved to a new thread: https://www.vintage-radio.net/forum/...d.php?t=139211
AC/HL is offline
Old 28th Aug 2017, 2:45 pm   #3
Oliver35
Oliver35's Avatar
Ohhh they're a pig. I put a new flex on an 'Ormond' hair dryer, and it was just as you describe. If you don't reassemble them in the correct order, they won't go back together. Must have been someone's unenviable task to wire those all day long, once upon a time..
Oliver
Oliver35 is offline
