Old 4th Mar 2009, 6:17 pm   #1
binthere
Question Philips 4307 4 Track. Advice required.
I have just taken possession of a Philips 4307 together with 6 tapes which otherwise would have been consigned to the tip.
My problem is that I do not have any of the accessories which may have accompanied the machine when new. What would these accessories have been?
Consequently without a microphone I have no means to record.
I would be grateful if anyone can direct me to a location where I might be able to acquire a microphone and any other accessories.
binthere is offline
Old 4th Mar 2009, 8:29 pm   #2
DOFFERY
Default Re: Philips 4307 4 Track. Advice required.
Any mike of medium impedance would suffice, also you can record direct from your tuner/amp to the 4307 via a 3 pin DIN lead.
Colin
DOFFERY is offline
Old 5th Mar 2009, 3:14 pm   #3
AndiiT
AndiiT's Avatar
The 4308 would have been originally supplied with a Philips N8302 500 Ohm impedance microphone, which exhibited a cardioid characteristic, and also a 3 Pin to 5 Pin DIN to DIN lead Philips reference number EL3768A/10.
As Doffery has already mentioned any microphone of medium impedance should suffice, the Philips N8302 or the Grundig GDM313 being ideal choices (both being already fitted with the correct mating plug); these microphones both occasionally crop up on eBay.
The DIN connecting leads, which allow you to record direct from a Radio or Record player may be obtainable from the likes of Maplins, R.S or Farnell but these days 3 pin DIN connectors aren't all that common.
Regards
Andrew
AndiiT is offline
Old 5th Mar 2009, 6:50 pm   #4
DOFFERY
As some of the earlier 4307 machines were fitted with a 3 pin DIN socket, all you have to do if you obtain a 5 pin lead is cut off pins 4/5 .
Colin
DOFFERY is offline
Old 5th Mar 2009, 7:07 pm   #5
binthere
Many thanks guys.
binthere is offline
