Go Back   UK Vintage Radio Repair and Restoration Discussion Forum > General Vintage Technology > Websites
Websites Found an interesting website? Post the details here and share it with the rest of us. Please stick to websites that are in some way related to our hobby/interest.
Old 31st Aug 2017, 2:05 pm   #1
ms660
ms660's Avatar
Default Kirchoff etc ??
I'm not qualified enough to comment on what he says or the experiment shown towards the end of the video, best watched from 27:16 in to save time or start at the beginning if you have time:
https://www.youtube.com/watch?v=nGQbA2jwkWI
Anyone?
Lawrence.
ms660 is offline
Old 31st Aug 2017, 3:42 pm   #2
Nuvistor
Nuvistor's Avatar
Default Re: Kirchoff etc ??
Neither am I but it was interesting.
Frank
Nuvistor is offline
Old 31st Aug 2017, 7:52 pm   #3
peter_scott
peter_scott's Avatar
Originally Posted by Nuvistor View Post
Neither am I
Ditto.
The voltage measurements make sense for the loop current. As to the apparent difference, we are looking at a transient rather than the steady state. Certainly a surprising experiment though.
Peter
peter_scott is offline
Old 1st Sep 2017, 12:26 am   #4
Argus25
No Longer a Member
I think this is exactly the point. We can't expect to see transient voltages induced in a loop by induction, in either amplitude or polarity, match that of a steady state condition, as his experiment elegantly points out. The same applies to steady state conditions that occur say after the oscillations in a resonant circuit have decayed to nothing, versus the conditions when the circuit was previously oscillating and energy was exchanging between the reactive components. But it is a really good example of the trap one could fall into measuring voltages around a loop.
Argus25 is offline
Old 1st Sep 2017, 9:19 am   #5
ms660
ms660's Avatar
These notes by Prof. J. Belcher (slightly amended by W. Lewin) might be of some use in trying to explain things:
http://web.mit.edu/8.02/www/Spring02.../lecsup4-1.pdf
Lewin's supplement notes pertaining to the lecture he gave in the video:
http://web.mit.edu/8.02/www/Spring02...lecsup3-15.pdf
Lawrence.
ms660 is offline
Old 1st Sep 2017, 11:14 am   #6
Argus25
No Longer a Member
Those two articles are very helpful and explain how two voltmeters connected to the same place in a circuit can show an opposite polarity readings (and sometimes different magnitudes) when they are part of an induction loop where the emf is generated by a changing magnetic field in the loop.
This effect, as noted, is quite different from a battery generating the emf in the loop where its all so intuitive, where both volt meters would give exactly the same reading.
It relates to the fact that the voltmeter wiring and circuit for each voltmeter becomes part of the induction loop. Explaining why they can be connected to the same place, but show two different readings, which seems counter-intuitive and it is not the kind of thing we would expect to see with the typical daily use and application of a volt meter.
Argus25 is offline
