Go Back   UK Vintage Radio Repair and Restoration Discussion Forum > General Vintage Technology > Websites
Websites Found an interesting website? Post the details here and share it with the rest of us. Please stick to websites that are in some way related to our hobby/interest.
Old 28th Aug 2017, 1:41 pm   #1
Default R-type org ???
Not working here at the time of posting this:
http://www.r-type.org/exhib/aaa0028.htm
Old 28th Aug 2017, 1:46 pm   #2
Wendymott
Wendymott's Avatar
Default National Valve museum
Hi peeps..... Have I missed something If I try to log onto the National Valve Museum.. it is coming up with some...www type -R site.
Maybe one or two of you can help. in my eddy S750 the Audio output valve was damaged. I used the N78 from my 888..... and it was ok.... however when I fitted its "equivalent" 6AQ5/ EL90..... into the 888.... I get flashing and popping at the internal pin base.
Re fitting the N78 back into the 888... normal ??
As I cannot check via the Valve museum... I hope you guys can help.
Should get out more.
Wendy G8BZY
Wendymott is offline
Old 28th Aug 2017, 1:50 pm   #3
Reelman
Reelman's Avatar
Default Re: R-type org ???
Same here!
Perhaps they forgot to renew their domain rental. Same thing happened to our club.
I would really miss them if they went, always use the web site even though I have their DVD.
Peter
Reelman is offline
Old 28th Aug 2017, 1:52 pm   #4
Nuvistor
Nuvistor's Avatar
Default Re: National Valve museum
The museum must only just have gone off line, I cannot use it now but is was ok earlier this morning.
I will have a look at what valve info I have but may lack the ones you need.
Frank
Nuvistor is offline
Old 28th Aug 2017, 1:54 pm   #5
An alternative for the moment, no pics though:
https://frank.pocnet.net/sheetsD1.html
Old 28th Aug 2017, 1:57 pm   #6
Wendymott
Wendymott's Avatar
Dohhhhhhhhhhhhhhhh.... Found Radio Museum..... and the answer to my problem..
N78, has pin 6 as N/C 6AQ5 has pin 6 as G2 and Pin 7 as G as well as Pin 1
The eddystone data sheets originally stated that the N78 and the 6AQ5 were the same.
Must have been a typo... long ago.
Thanks Frank
Wendy G8BZY
Old 28th Aug 2017, 2:02 pm   #7
Nuvistor
Nuvistor's Avatar
Just have the same info and was about to post, however the site Lawrence posted is another good site for valve information, in fact the valve museum credits a lot of the data from that site.
Frank
Nuvistor is offline
Old 28th Aug 2017, 2:36 pm   #8
ukcol
ukcol's Avatar
I use both those sites all the time (most recently yesterday). They are both excellent sites with different merits.
I do hope this loss of the Nation Valve Museum is not permanent.
ukcol is offline
Old 28th Aug 2017, 2:40 pm   #9
Oliver35
Oliver35's Avatar
That's extremely worrying. I use that site very regularly- it's part of my ongoing learning curve re valve electronics- I should guess that 50% (at least) of what little I do know I learnt from that site. Is any member here connected with it?
Oliver
Oliver35 is offline
Old 28th Aug 2017, 2:50 pm   #10
I wouldn't worry...
a) An administrative cock up, registration expired, soon back after payment.
b) If someone has 'hijacked' it (the domain name, not content) during the lapse (popular ones often are) it will re appear under a slightly different name.
The internet is a bit of a cowboy effort, and expect it to be so.
Old 28th Aug 2017, 2:50 pm   #11
Nuvistor
Nuvistor's Avatar
Oliver
Too early to worry, it's bank holiday, a privately run site and computer networks break.
The owner no doubt will get it sorted out when they can.
Frank
Nuvistor is offline
Old 28th Aug 2017, 2:51 pm   #12
Clicking on that link now is showing something but not everything, maybe it's starting to be reloaded? I know zilch about these things.
Old 28th Aug 2017, 2:57 pm   #13
Nuvistor
Nuvistor's Avatar
Looks like the front page/ index page is giving trouble, navigation to other links on that page work.
Try tomorrow or the day after, plenty other things to do on a bank holiday and the sun is shining.
Frank
Nuvistor is offline
Old 28th Aug 2017, 6:37 pm   #14
Nuvistor
Nuvistor's Avatar
It's back on line again.
http://www.r-type.org/static/advert.htm
Nuvistor is offline
Old 28th Aug 2017, 7:08 pm   #15
ukcol
ukcol's Avatar
Excellent!!
ukcol is offline
