12th Jan 2014, 7:46 pm | #1 |
Adding RF input to vintage TV - JVC Videosphere.
Hi everyone
This is my first post here, even though I signed up nearly 5 years ago! I've recently acquired a JVC Videosphere TV from the 70's. I'm looking to add an RF input to it. Can anyone help me out with what parts I should use and where it should be connected? UHF or VHF? Please ask for any more info |
12th Jan 2014, 9:51 pm | #2 |
Re: Adding RF input to vintage TV - JVC Videosphere.
The RF input (UHF or VHF) is already present. Maybe you are looking for a modulator?
12th Jan 2014, 10:01 pm | #3 |
You could use a freeview box with a RF output
I have a RF modulator which I attach a Scart to so I can view outputs from many sources eg VHS Either will suffice. Considering its age UHF should be the input to use This is the one I use http://www.amazon.co.uk/Universal-Sc...s=rf+modulator though available from many sellers |
12th Jan 2014, 10:11 pm | #4 |
Or a redundant VCR if you can hide it-doesn't even need to work tape wise! Lots of threads on here eg Camtechman 7/11/12 "Using a Freeview Box On a TV With No Scart Socket".
Dave W |
12th Jan 2014, 11:01 pm | #5 |
Thanks for your replies guys.
There isn't a normal round RF connector on the back of the TV, only a bizarre 2-pin socket that I've never seen before. The black UHF socket as shown in the video here, is missing from my set. CLICKY There are 2 spade connectors leading to where the UHF socket was. Could I get an old RF cable, cut the end off and wire it to the spade connectors? Effectively giving me a round RF socket? |
13th Jan 2014, 1:19 am | #6 |
Before doing that, be sure there are no isolating components which may have been part of the black 2 pin uhf socket which is now missing. If you just connect coax to the bare wires, for all you know it could be a death trap. Maybe someone here has a schematic they could look at to confirm.
Regards, Ben. |
13th Jan 2014, 1:22 am | #7 |
Couldn't play the video, but you might have an IEC socket on Your set. Which is a RF input.
13th Jan 2014, 8:48 am | #8 |
There is an IEC socket, but I thought that was just for mains power.
The spade connectors both clip onto a little board inside. Then from this board, there's a wire that connects to the VHF (I think) will try to take some pics. Or, there is a telescopic aerial with the set too, could I just remove that and got an RF input there? |
13th Jan 2014, 12:45 pm | #9 |
This set may well be the European version which has a 300 Ohm balanced input. The safest / easiest way to connect is to use a 'balun' - these can often be found on the end of the loop aerial on portables which have a loop aerial with about a foot of ribbon feeder - the little black box on the end is usually a balun. A permanent and less lossy connexion can be achieved but you MUST ensure the mains isolation status of the set and use an isolated coax socket for the connexion. The tuner, if it is the European version, will most likely be a multi-band VHF/UHF job; by this set's era VHF only had dissappeared in Europe. Note also if it is the Euro version the sound intercarrier MAY not have been modified to the UK standard.
13th Jan 2014, 1:07 pm | #10 |
Here is the connection you will require link is for reference only
http://www.ebay.com/itm/TV-ANTENNA-L...-/321288711412 |
13th Jan 2014, 1:13 pm | #11 |
I'm guessing it is a european model as it's got a 2-pin mains plug. I've got a converter plug to make it 3-pin so no problems there.
Have looked around online and the only baluns I can see are used as an input to the TV. I'll whip the back off the set and take some photos, they'll be better than how I can try and explain it! Thanks for the link, but I'm in the UK and the cost of shipping from the US is pretty steep! I've had a look at ebay.co.uk but there's nothing similar on there. I thought it would be as easy as wiring in a bit of coax cable and a new socket! :p |
13th Jan 2014, 6:52 pm | #12 |
Does the socket look like it would take one of the VHF or UHF 2 pin aerial plugs shown in the attached PDF, which is from the 1969 KJ catalogue?
13th Jan 2014, 11:16 pm | #13 |
It would take the VHF plug by the look of it.
Are these available anywhere? |
16th Jan 2014, 10:44 am | #14 |
I took the back off the set the other day and took some photos. I'm hoping now that these are up, you guys would be able to give me some help with what to connect and where. I've bought a balun as per someone's suggestion.
Last edited by AC/HL; 16th Jan 2014 at 9:00 pm. Reason: Images converted to attachments |
16th Jan 2014, 11:04 am | #15 | |
16th Jan 2014, 11:47 am | #16 |
I'm just looking to connect an old games console to the TV, an Atari 2600.
I'm not looking to connect anything via Scart, so would I still need a modulator? Thanks for the offer mate, if you think it would work, that would be great |
16th Jan 2014, 8:06 pm | #17 |
That's the exact modulator I use with my sitting room TV which doesn't have scart - and it's really good for the money. Better picture than a couple of other more expensive modulators I own, and the digital channel selection is much nicer than those difficult little dip switches too.
17th Jan 2014, 8:25 pm | #18 |
The Atari 2600 has a built-in modulator, you shouldn't need another one. The main problem is the UHF aerial socket has been removed from your TV. I'm assuming the two wires that plug in to the tagstrip behind the aerial sockets are used to carry the aerial signals to the tuner. You can try connecting the RF out from your Atari 2600 to those wires. It's quite safe - the JVC Videosphere chassis is isolated by the mains transformer inside the set. Then just switch on the Atari 2600 and the TV, then turn the UHF tuner and see if it picks up anything.
No need to worry about using a balun. Without one, some signal will be lost due to impedance mismatch, but in practice a modulator will give out so much signal that some loss won't matter. |
18th Jan 2014, 8:09 am | #19 |
Thanks for the info mate, will give it a try. There never was a round RF input on these TV's, that's why I'm trying to add one in now
18th Jan 2014, 9:42 am | #20 | |
It would be better to find out more information on the TV itself and find out if in fact it is UHF capable. The fact that the video earlier shows one with a UHF socket, doesn't mean that all models had one. Rich
